1g bad pcv valve every 2 weeks...
yotabeater
62
May 14, 2004
Auburn, Washington
every 2 weeks my pcv valve goes out. i can hear it making a loud ticking noise which the knock sensor picks up and results in part throttle phantom knock of 43. this is really starting to piss me off, as i now have a stock pile of pcv valves. if anybody knows how to get rid of this problem, i.e. modification or a certain one to buy, let me know. i have bought out most of the pcv valves in every store in a 10 mile radius. thank you.
i bought three PCVs, two from AZ, and the other from O-reilly... all gave me HUGE boost leaks.... pick up one from the dealer...
Do what I do Cap and vent. Cap off the fitting on your intake manifold and attach a hose to the pcv valve and vent it to the atmosphere. I have never had a problem doing this.
So would you say the PCV valve is only there for emissions reasons and not reliability reasons also?
2.4 turbo Hyped said:
Its an emissions thing, just like everything else thats not on my car its gone. Sean
i agree, i never had any probmels with the PCV to atmosphere on my 91. all that stuff is there for emmisions, and it can all be removed. PCV, charcoal canister, EGR, can all be bypassed or removed. all of it has been removed from my 91, and iv never had any problems relating to it.
or just remove it alltogether, like on RRE's site
After dealing with the same problem numerous times I'd also recommend that everyone run the PCV to a catch can. I've bought three PCV valves from Mitsubishi and within a month or two of driving they no longer seal under boost. This causes my valve cover gasket to leak a bit of oil, tries to push out the dipstick, and pushes a lot of oily crap through the breather.
DSMeclipse4G63 said:
check your compression, youll most likely have a blowby issue...
All within 160-150. It's the PCV valve every time, confirmed by a boost leak test run at 20 psi.
thanks to all that have replied.
i already had the intake manifold hole plugged, and the pcv valve re-routed to the atmosphere. i think i will try and remove it all together today.
i know i don't have blowby issues, i have 170 compression in every cylinder.
i will let you guys know of my results. thanks!!!
What I meant to say is a leak down tes...your motor may hve good compression, but that could all be due to carbon deposites. Besides I was originally replying to the thread starter, I in no way disbelieved you :thumb:
Andrew
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
