1g AWD front hub outer diameter
DSMopar
615
15
Oct 6, 2007
Vista, California
Anyone have a front hub with the brake rotor off floating around? I need the O.D measurement (with calipers plz). This is for a set of brake rotors that need machining.
The hub is the wheel bearing but your asking for a measurement with the caliper? So you need it measured from where? The hub flange center or outside of the flange to the edge of the caliper?
