1G auto- car goes dead lean after shift
11secDSM
749
9
Sep 8, 2003
Collegeville, Pennsylvania
This one had me stumped. My 91 auto goes dead lean after any shift...WOT or 50% throttle, doesn't matter. If I do a full pull in any of the gears it doesn't happen. I've checked for boost leaks, replaced the pump (which is rewired), replaced the AFPR w/ a stocker. No knock prior to it going lean. Nothing on the log gives me any clue as to what the issue is.
It's a simple setup...
E316g
walbro
link v3
aeromotive afpr
evo 560cc
2g mas
Any ideas?
Link to a log I posted on Link forums...
Link to datalog
That is what lean would point to, at least in my case. I'm fairly sure the OP means the same, as he makes reference to knock.
I do, goes 20 then ----- when I hit anywhere from 50% to WOT and the car down shifts. OP did you figure out what was causing this issue for yourself?
