Resolved 1G 4G37 Bad ECU?
Nautica985
320
Dec 2, 2002
Baltimore, Maryland
My #3 injector is not injecting. The injector it self is good because i swapped the #2 injector with #3 and it still does not work. I listened to it with a stetshiscope (sp) and it is not ticking, all of the other injectors are. It gets power and I know the ground wire that goes to the ecu is intact because when i ground the wire at the ECU the injector ticks when i listen to it with a stetsiscope.
This is on my 92 1.8. What year ECUs are compatible for the 1.8s. VFAQ only has ECUs for turbos.
What I would do is get pin locations for the 1.8 ecu and a cheap multi-meter and make sure both injector wires are ok. Do this by checking the resistance (Ohms) and check the book for the correct readings. Does the ecu make ticking noises like the injectors almost or does it smell like fish? Also while you are at it, check ecu grounds.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
