1G 2.0 non turbo Fuel Pump
SnP9000
45
8
Nov 12, 2023
Chicago, Illinois
Hey DSMers,
I'm throwing a pump at my mom's 92 Eclipse GS non turbo fwd. Looking at rock auto, they show 2" diameter pumps with ring terminal posts, and 1.5" diameter pumps with a connector. What do I need to buy? I suspect the ring terminal version might be the "OEM style" and the 1.5" might be a universal solution. I am looking for the version that requires the least dorking around to make universal parts fit, with heavy preference for a plug and play R&R job so I can get back to my own projects. What part do I need to buy?
thanks as always for the advice!
Luke
A 1992 non-turbo would have been originally equipped with the smaller diameter pump that uses the harness with connector, rather than the ring terminals. 1990-1991 version on the left and 1992-1994 on the right.
Worst case, if it happens not to match when you pull it out, you can order this pigtail connector as well which you can use to easily convert yours to accept the pump that uses the pigtail connector.
