1g 17" wheel question
soulcontroller
61
Jun 11, 2002
1991 talon AWD.
ok, i've got a set of 17x7 lenso VPD wheels that im going to be putting on this summer. the offset is 38, and i will be installing HnR sport springs and AGX's/camber kits at the same time.
is a 235/45/17 wheel going to fit alright? i would rather have a 235 over 225, but if it wont work, then ill have to settle.
comments?
235 is a little wide for 17x7" rims, but people have done it. Personally I'd not run anything higher than 215 on a 7" wide rim - at 235/45 your sidewall height will be a little higher than normal, and so the car will be raised a little bit and your speedometer will be off. You may potentially have rubbing issues as well, as a result. 225/45 is identical to stock diameter, so it's really the most ideal, with a 7.5" rim - but you should be able to use it on a 7" rim just fine.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
