Spyder 1999 Eclipse Spyder power mods?
Gotsclout
Dec 12, 2022
New York
I have the 2.4L N/A version and wanted to know what mods are good / possible to produce more power
Take a read through this:
in my opinion I suggest leaving it as is, opt for a gst if you want more power. There is too little support for the 2.4L and you can only do so much especially on budget.
The factory turbo manifold bolts right up. Obviously you would need a custom downpipe and tuning mods but it can be done.
A gst downpipe bolts right up right well.
To OP. A turbo setup is the only power option for 2.4. Most all GST turbo parts bolt right up. Youll have to tackle the oiling setup for the turbo, upgrade injectors (if you use low impedence like stock gst injectors, youll need to wire in a resister pack), upgraded fuel pump, a way to tune it, etc.
OP - what is your budget and what are you looking to achieve? To some people "more power" looks like getting an extra 50 hp out of the engine. To others it looks like putting 500 hp to the ground.
Only trying make about 300
