1999 Eclipse Auto Trans doesn't work unless warmed up.
crazysweetguy
Nov 6, 2010
Sandyville, West Virginia
What would cause a 1999 Eclipse Automatic transmission not to work properly unless the car is warmed up for a few minutes? Someone has a car for sale but has this problem. He had a 6 bolt engine installed not long ago and I am not sure if that had something to do with it or not.
Low ATF level. Be sure to check the level in neutral, not park, with the engine running and after briefly selecting every gear. Checking the ATF wrong will cause the level to read Ok when it is actually a couple of quarts low.
After warming up the fluid expands and the tranny works ok, well better anyway.
