1995 talon wont Idle on a cold start
em5780
67
Sep 16, 2008
bogota, New Jersey
hey my 1995 just started giving me problems with idling when it was from a cold start. I need to hold the gas a little bit to keep it running but when the car is warmed up it idles fine. im sure this is a quick fix i just dont know where to start.
Check your Idle Air Control and your Coolant Temperature Sensor. Check the CTS first as that is the most common issue with a rough idle until warm up. Also if you can check to see that your o2 sensor is functioning properly if both check out ok.
