1995 Talon TSI Boost
Projectwhompskew
Jan 17, 2013
Melrose, New York
Hi all, running a stock 1995 Talon TSI (was told was lightly internally modded but no signs of any significant work done) Having a issue here. im runnnig aproximatly 20-28Lbs of boost, everything functioning properly, but hitting fuel cut at over 28LBS. Is it possible to have tapped my gauge into a bad location?
Thanks
Jake :banghead:
I you should not run your car at that boost without proper modifications. I wouldn't recommend anything more than 15lbs. As long as your gauge is accurate and you are tapped in on the intake manifold you can't go wrong. I run mine off a vacuum T between the fuel pressure regulator and the manifold port. I'm surprised you have blown a head gasket or worse running that kind off boost
Do you have a boost gauge installed? Without any supporting mods I would keep it in the safe zone 15 and under for boost. I am guessing that you don't have a boost gauge you are guessing (approximately). That's a lot boost for a non modded setup. Follow the basic upgrade mods in the tech files. Is your profile correct? You have listed cams (which) and injectors. Have you logged this event? You have ECM link listed.
