1995 eagle talon tsi
Codytalon95
Aug 3, 2010
Rochester, Pennsylvania
Hey i have a 1995 eagle talon tsi it has evo 3 manifold, big hole lifters, hks cams, Injectors, full 3 inch exhaust, cold air intake, fmic, evo 8 bov, and a precision 50 trim turbo i need to replace what is a good turbo to replace it with under 800 dollars i need help please help!!!!
I'd go with an evo3 16g. For the money you just can't beat it for quick spool up as well as great airflow #'s.
agreed if you shooting for 350-400hsp then evo3 16g s the way to go,, way under your 800 dollars and solid turbo, maybe look into a hx35 or hx40 off the trucks but those arnt as responsive and take a while to spool
Big/Evo3 16g. The small 16g drops off on top end and higher psi efficiency but only by a small amount. But still used they are about the same price.
