2G 1995 GST OBD-II Scanner Brand Compatibility? Is 1995 4G63T 2G GST OBD-II a Myth? 😱
LunaDSM
Jul 9, 2021
Cavite, Philippines, Asia
Hey guys, @LunaDSM here.
So I have been using this specific simple/cheap/low end OBD-II scanner way before I owned a 2g Eclipse.
Even though it is a low end scanner, it works on any car I have tried it on and it definitely serves its purpose.
The Launch Creader 3001 OBD-II Scanner....
A reliable scanner.. (until i tried it on my 2g 1995)
My 1995 Eclipse is equipped with an OBD-II port. Although it is not the OBD-II from 1996, I am wondering why this scanner does not work with my 2G.
I can't find a specific OBD-II scanner for 1995 vehicles (because there's probably NONE)
Does anyone of you experienced this with other scanner as well?
Which brand/model works with our 1995 Eclipse? (low end scanners just to read out codes)
Note: Honestly, I can't afford high end scanners. I just need a handy tool to read out codes (cause why not?)
Cheers! :thumb:
I cant seem to find an OBD-II scanner that works on my 1995 4G63T eclipse.
Is OBD-II for 1995 eclipse a myth? 🤔
(Not all cars with OBD-II port are OBD-II Compliant)
Anyone who owns a 1995 4G63T Eclipse that can send me a link of an obd scanner that works?
(Not a shop scanner, for personal use only)
Thanks!
Hey! Have you found a scanner that works? I'm facing the same issue right now.
So from what I know you may have to get a obd 1 since the 95 is one of the early models technically and then you would need to either get a adapter from a obd 2 to a obd 1 or u could set your laptop up for ecmlink
