2G obd ii p1105
david2450
Jul 1, 2009
somerset, Kentucky
I have a 97 GST and the check engine light came on the other day. An I finally checked it and i got the code P1105. Anybody know what that is?
I know something to do with the fuel. When you first start it up it idles real bad the rpms just up and down like its about to die but if you press the gas it gets better. An if you let it sit for maybe thirty mins but the motor is still warm and you start it up it will do it, but get better after you press the gas.
An today I was driving it an went to second gear and got on it and it started missing but only for a couple secs then went back to normal. I also don't think its fast as it should be like it ain't getting gas or something.
If you can help me out thanks.
