420A 1995 Eclipse Clutch?
Arnie
800
Mar 29, 2012
San Diego, California
My clutch works, but I need to change it. It's for a 1995 Eclipse RS.
I'm not sure, but when I drive it sounds like something is dragging on the floor. Not sure what that is?
What kind of clutch kit would I need to buy?
( Sorry I'm new at this and don't understand it much any help helps out Thanks for your time DSM'ers )
Why do you think you clutch is going out? Is it slipping?
When you drive it, it sounds like something is dragging on the floor?? What does this mean?
The floor, as in the floorboard to your car? Or by floor do you mean ground?
The best way for me to check for a bad clutch is to park it, pull the e-brake, put it in 5th gear and 'launch' it. If you hear it kind of drag for a couple seconds then die after the clutch is engaged, you have a bad clutch. If it catches and dies almost immediately, your clutch has life (or some) left in it. Another way if you're not comfortable with that is to take it on the road and shift into 5th gear at around 30-40mph and floor it. If the rpms increase without you actually gaining speed, bad clutch (slipping).
It's probably your input shaft bearing. Lookup videos on youtube of the Dodge Neon doing the same thing. Does it make the noise with the clutch pressed in or clutch out (driving around) ???
Chris
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
