1993 laser, $1500?
StandBackImaPro
51
Aug 15, 2005
Brick, New Jersey
Friend of a friend is selling his 1993 laser n/a for $1500 bucks
Has..
new timing belt, new water pump, just hit 101K, stage 1 turbo trix trans rebuild, comp racing 101 cams, hks valves and retainers, apex i superground pace setter header, new head gasket, new balanshaft belt , cam seals, injen cold air, taylor 8.5 wires and ngk plugs
headgasket never blew or anything, he just built it up
All it needs is an A/C belt,
and it dosnt have power steering...
but i really need a car, and i got 3k
i just need a daily driver for now, andm hoping this is it,
I work at an oil change so ill be changing the oil with mobil 1 synthetic all the time
You will deffinately be wanting a turbo after having an NA for a while. I'm in that same situation. However, I'm heading off to college next month and can't be bothered with all the extra maintenance that comes with a turbo car. The mods that have been done to that car will make it a fun car even without it being turbo though. I happened to find a wrecked 91 laser with an Injen I got off it for 50 bucks and love it.
Trust me spend your money on a turbo, after seeing what they can do that is what I want. But if you want the car realy bad I say go for it. I have seen some really neat n/a cars and you might not be into turbochargers.
i got my turbo laser for 800 from a friend, and put alot of time and work into and looks a WHOLE lot better then when i bought it. Do what everyone else says just wait around till you find that right deal on a turbo. If i can do it for 800 you will be set with 3k. :thumb:
