laser part out
the "laser"
204
Jun 13, 2008
Boone, Iowa
decided to part out my laser. any "each" items (doors, fenders etc) i will knock off $10 if sold together.
long block: $700 W/WO port job, W/CAS, full gasket set, but engine only (no fuel rail, injectors, intake or exhaust manifold) includes water and oil lines
short block: $550 W/full gasket set, $500 W/O
head: $200 W or W/O port job and W/CAS. havent taken off to see if anythings wrong, will update price when i get it off if anythings wrong with it.
CAS: $40
valve cover: $30 W new gaskets (missing some bolts)
gasket set: $60. new, OEM gaskets including head gasket
intake manifold: $55. looks to be in good condition. could use a cleaning. comes with studs.
TB: $45. looks to be in good shape. will clean before pick up
intercooler setup: $105. includes j-pipe, LICP/w bolts, bigger SMIC and hard UICP with TB elbow and 1g BOV. (will sell BOV seperate too)
BOV: $40
suspension: $155. koni struts with eibach sportline springs. lowered it about 1.5"-2" in and handled like it was on rails
brake setup: $130. 2-piston front calipers with newer pads and rotors with SS braided brake lines all around.
goodridge SS braided brake lines: $55. looks fairly new.
fenders: $20 each. standard rust holes in corners but will grind out and try and seal it. a little bent from taking off too, but paint is good.
doors: $60 ea. glass is in excellent shape and has power mirrors option. no panels.
rear hatch: $70. glass is in great shape with rear defrost. no struts
front corner lights: $30 ea. in great shape and free of scratches or fading
rear lights: $50 for set. in great shape with no scratches or fading
front bumper: make offer. comes with ALL hardware. some bolts have busted off from rust so needs removed, but in pretty good shape and paint is good
hood: $65. some clear coat fadeing, but paint is in good shapewith no dents or dings or scratches.
glass: make offer on what you need. ALL glass is in great shape with NO cracks, including windsheild. (door and hatch glass not included. you remove)
seats: $50 ea. comes with brackets. in GREAT shape.
shifter with cables: $30. in pretty good condition. could use a cleaning.
current tranny: $80. FWD turbo 5-speed, grinds going hard into 2nd but otherwise works great
extra tranny: $100. is a replacement for the current tranny. was told it is good
fuel rail: $40
MAF translator and GM MAF: $210. brand new never used with 2 mafs
stock parts: make offer. have intercooler setup and mafs, maybe some other things.
dejon dual stage MBC: $40. not sure if lo-hi or med-hi.
reman alternator w/ warranty: $50. needs a good cleaning but works great. will include bracket and belt (if belt is good, not sure though)
new direct fit cat: $60. is currently on car but will clean up before purchase
newer plugs and wires: $25. low miles on them, maybe 100. will clean the plugs and make sure they are properly gapped before purchase.
autometer A/F gauge w/ holder: $25. never hooked up and is narrow band
O2 housing w/ sensor: $45. dont think it has any cracks as its still on the DP. will check when i get it off. sensor was replaced before i bought the car by previous owner.
more to come.
