1990 Laser Turbo help
33LaserRS93
39
Apr 4, 2009
Topeka, Kansas
Rear brake is sticking and has a oil leak in the turbo return line, will include new gasket.
I hear its hard to seal up an oil leak from the turbo return line. Have any of you ever done this fix before.
If you have any help would be appreciated. Thankyou.
If your rear brake is sticking then there is a good chance your e-break cable is sticking. Take the end of the e-break line off your caliper and see if you can move the cable freely back and forth, if you can't then you need a new one.
The turbo return is easy to fix. Get a new gasket and put it in there..
As long as nothing is kinked the wrong way its an easy fix. If your really not sure use a little silicone, and I do mean a little.
