silvershark
- 0
- Nov 11, 2010
Anchorage,
Alaska
Ok, so I was helping a buddy try and troubleshoot his no start problem today and we were still unable to get it to start.
Here is what we tried.
Checked fuel pressure 43psi. Check spark, no spark. Air seems to be fine.
So we started troubleshooting the spark related stuff, checked the CAS, we get 12v on the red wire, 5v on the small black, 5v on the small white, and the ground wire looks fine. Cycled the CAS manually and can hear the injectors spraying, the 5v cycles 4 times as it should, and the other 5v cycles 2 times as it should.
We then checked the Coil Pack using resistance tests. I got 12.2ohms between the first pack and the second pack where the spark plug wires attach. This seems to be within range of 10ohm -14ohm. I then tried to check the 4 connector plug and it shows 0 ohm on all 3 of the connectors and 12v on the power supply wire for the 4th connector. So this seems legit. I even went down to the parts store to check with my multimeter and the new one read about the same.
We checked the 6 pin connector that connects to the coil pack using the 1.5v AA battery test with a light bulb and that worked fine. We have two of these modules along with 2 of the coil packs. We have tried swapping both and it still wont start.
The MPI relay works fine. I removed the MPI fuse and noticed on the 6 pin pack, you get 2.5v on pin 2 and pin 5 when cranking and when you remove you do not get any voltage. So it seems you need the MPI fuse or it wont start period.
So I pulled the spark plug wires and attached a brand new plug to the end and I see no spark. I am STUMPED. The only logical thing I can think of is the ECU is bad... This seems unlikely as the CAPS were replaced about a year ago.
The other weird thing, when I did the light test to the 6pin connector that connects to the coil pack, it requires 12v to either pin1 or pin6 to test the module.... At no time when cranking did I see 12v to either pin 1 or pin 6. Can anyone verify with their running dsm if they are getting 12v on either pin 1 or pin 6 of this connector? This seems like the only likely thing to make sense other than a bad ECU.
Please help, I want to get this car back on the road!
