Evo-Jr
- 125
- 2
- Mar 23, 2006
brooklyn,
New York
Hey guys.. After been play by one of the vendors on the sitenow dont know what to do, they wasted 3 month of my time. I need help on trying to built a 6 bolt. Looking to make around 600-650hp.. I had order a 2.0 long rod for the car, now i have all this parts laying around my house.. ACT 6 puck clutch, fidanza flywheel, oil pan, OEM MLS Headgasket, arp head studs,Magnus heat barrier gasket, water pump and timing belt kit etc..
The head has a little bit of work, 3 angle valve job, SI dual spring and retainers, SI valves the nitro something. I forgot what they call, 272/264 hks cams.
T4 tubular manifold with a precision 6268 billet wheel, fic 680cc which definetly i have to change, Bosh 044 fuel pump which it would be mounted by the engine bay since i have a 255 walbro intank
Now i dont know whether to go with a 2.0 block or a stroker, i know the turbo i have needs a lot to be able to spool up thats why im thinking of a stroker motor. Like we all know dsm trans dont like to shift at high RPM even tho i have a built stage 2 sheptrans...
I dont know if i explain myself enought, but botton line i just need help since all my friends are into civics not DSM.. Need a nice combo to reach my goal. Thanks
