16g turbine housing stud size?
97ebaygst
326
Oct 8, 2009
thomasville, North Carolina
I have been searching on here the the proper stud size for my o2 housing to turbine housing . On the front side of the o2 housing it curves over to where I can't get a bolt in there. I saw extreme psi has a set on there web site for the 3 bolts and stud but I only need the stud. So if anyone has the info on the the measurements I'd appreciate it.
m12x1.25, Atleast thats what I bought for mine. I got the stud from ACE. Also, if you use stock O2 bolts, you can get it to fit by putting the bolt through the O2 housing before installing it.
Thanks to you also.LOL without you this thread couldn't be possible. Seems that my stud decided to come out instead of just the nut and I could not get that nut off! It is on there for good along with my o2 sensor! Dang it 21 year old parts!
Man that sucks.
And if you can't find a stud advance auto parts has a dual pack that's 40.5mm long that I got. It's in there exhaust section hardware section if you need it.
