turbo bolt/stud options... torn up turbine housing
mike96
1,010
22
May 6, 2008
Phoenix, Arizona
OK so now i find myself at a dilemma that needs a solution... luckily my car isn't a DD right now so i really am not to worried about it and it doesn't need to be done right away but... currently i have a 96 talon that i put my built 7bolt from my eclipse into, i am nearing the resurrection but now have stumbled upon a problem. while removing the E316G from the engine for the third time in an hour everything went bad. i had put the turbo on the engine about two weeks ago so that i could try to start fabing an exhaust but then this last weekend before getting started i had pulled the turbo to try fixing a couple of things (i didn't like the way the coolant lines ran). so i pulled it snagged the lines tried putting it back on (didn't fit with the lines i had on), pulled it again fixed the lines then put it back on again. so i got 3 of the 4 bolts in and while getting the last bolt in it froze about half way in. stopped turning compleatly..... this was with light hand pressure using a wrench mind you, no gorilla torque, i was anticipating having to pull the turbo again any way just not for this. so i Pb blasted the bolt best i could (driver side closest to the head) and started working on pulling the other 3 bolts while it sat........ driver side front bolt locked up after 2 turns.:mad: any way that was yesterday and after a few shots of Pb blast and sitting overnight one bolt striped loose and the other broke off. so long story short (sorry to late) i am going to take the turbine housing to a machine shop to have the remainder of the bolt removed because i honestly don't feel like dealing with it.
now my question is this..... 3 of the 4 bolt holes on the turbine housing are really messed up 2 of them look like this and the 3rd still has a bolt stuck in it. i don't really want to put another set of factory bolts in it for fear of having this happen again but i don't think a thread repair kit will do the job. with the exception of making it easier to replace gaskets with all bolts i was considering using all studs, this way if they locked them selfs into the turbine housing who cares, until i break a stud. or i was thinking of may be drilling the holes out and replacing the factory bolts with something a little bigger, 12mm or SAE perhaps. short of buying a new turbine housing, are there really any other options? i know moving up in bolt size will more than likely mean i will need to enlarge the manifold bolt holes as well......
if i go up in size something along the lines of these....
$12 VW Diesel Cylinder Head Bolts Set of 10 - Size m11 x 95mm VW Diesel TDI
they should keep the turbo in check and they more than likely are hardened......
I've used studs on my housing and it worked just fine. In fact I liked it a bit more because I could tighten it down more than with the bolts. I used a stud off of a BMW for temporary use, but I ended up leaving it on there it worked great. Just make sure you can access it depending on your manifold.
  • Wanted 6 bolt NT water pipe
    • chrisman287
