16g oil return line leaking..........
Talontid21
Banned Member
148
Feb 11, 2004
Minoa, New York
My 1990 Talon Tsi's 16g oil return line is leaking right where the ribbs are.Any other solutions besides dealers 63 dollar pipe?thanks :talon:
-Saw off the flex section, replace it with a oil resistance rubber hose, secure with hose clamps at each end of the hose.
The post above me ^
I actually had to do this today, it was to long after i installed my turbo back on the car because the header pushed down the turbo. I cut the flex out, Got a piece of hose and two clamps, Got it adjusted to my size, Clamped the clamps down tight :)
Are you sure that rubber hosing will work?I'm running 15 psi of boost------And also,what size hose did you use?Thanks guys!
:thumb:
:thumb:
-Lbs of boost has nothimg to do with the oil, if you worry about the hose slipping off the pipe, you can always put a small flare on each end of the pipe, I think it's 3/8" ID hose.
Just take the thing off, saw off the flex section, bring the two pieces into Pepboys and find the size hose that fits snuggly on there. Badda bing! Plus now it will be easier to pull on and off because it'll be much easier to allign since its much more malleable then the firm stock one.
