16g build with a few questions
eclipse012
183
10
Apr 17, 2008
canada, AB, Canada
Hello,
so i have just finished pulling my ecu from under my center dash to make sure its flashable with ceddy and ecu flash. And hurray it its! :thumb:
So during the time i was putting the ecu back i noticed a plug unplugged from under my radio area. I couldn't see any thing it would conncect to. Anyone know what it is for? (second and third pic to show this plug)
Last question is for tuning with Ceddy and ECU flash:
Tactrix Openport 2.0
I read that I need the tactrix openport 2.0 cable but do i need to get the reflash adapter in the top right column of the page for $10.00 with it? or the mitsubishi reflash connector at the bottom of the page for $11.00? Are they the same thing? I have read and searched for this already.
And i almost forgot i am trying to debate on where to run my wideband. I would like to put it in the rear O2 housing and remove my stock sensor since i am catless. I searched alot on this, and can't find anything on how to remove the rear stock sensor. Any posts with pics? Alot of people arguing that you have to remove the seat or not, then the thread stops.
Thanks
I can not help on the under dash plug, but I believe I ordered the Mitsubishi reflash connector. You can make one if you really wanted, search for posts from Ceddy.
Have fun flashing :hellyeah:
