BOOSTn20psi
- 120
- 0
- Nov 20, 2004
Aloha,
Oregon
Ok, I just installed my 14b I got from ebay. The has little to no shaft play. After everything was installed, I then turn on my engine and oil started leaking from the bolt from the feed line that bolts on top of the center piece of the turbo. I then took it off and reinstalled it and same thing happen again. How can this happen, I used twp different bolts. Does this mean that the turbo is bad.
Can I reuse the same NEW oil that I've just put in.
I've spend two days on this turbo and I am exhausted any help will be appriciated.
