14b turbo help
aznboi_106
Apr 26, 2010
Sacramento, California
@VelocitàPaola or anyone
i have a td05h 14b turbo i think its from the first gen.
i need to know which one is for coolant...
is it the tiny bent tube as the in and out is the side one? caz the top is oil feed and bottom is oil drain right???
i need help asap
yes the to ports on the sides of the turbo are coolant. The one on top is oil feed, and on the bottom is the oil return. Not positive whether the front or the rear coolant line is the feed or return, but onces its mounted the hoses should line up to the proper line.
