14b post install question
DurangoGS-T
69
Jul 6, 2004
Wichita, Kansas
hey i'll be installing a 14b here in a couple of weekends, but at the moment my car has a really blown t25 that passes a lot of oil. my question is, i'm sure there is (or will be) a lot of oil sitting in the LICP and/or the intercooler. i should definitely clean that out right? i know better than to take a shop's word for it but a guy said to me that there is no way to clean it out, which i say is bs. also, about how long will it continue to blow smoke after i get the 14b installed? when i start the car after its been sitting for a while the smoke is insane, but after a while it calms back down. thanks all.
When you have the turbo off just remove the intercooler and LICP. You can clean them with gasoline or some kind of solvent. Plug one of the outlets and pour some gas in and cap off the other end. You can just use rubber gloves and cover the outlet with your hand. Shake the IC pour the gas out, do this a couple times until the gas comes out clear. You definitly want to celan it as all that oil will lower the efficency of the intercooler. I noticed a difference in my old 1g after cleaning the IC.
The smoke should stop within a couple of minutes.
well, its actually kinda easy to clean the intercooler. the hardest part is getting the son of a bi*** out the first time. they decited to put a couple of bolts in some odd locations. Just pore a little gas into the intercoller and shake it up. do that a couple times. i even used a can of some carb cleaner. as for the fins. just use a pair of tweesers to straiten the fins. and some compressed air to get the bugs out. when all the oil is out of the way. it shouldnt take much longer then a couple min's for the smoke to stop..
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
