14.2@94; 15psi, bolt on's, clutch
BacknBlack92ESi
2,340
Feb 19, 2003
Kansas City, Missouri
Wen't back to the track after the clutch was broken in.
Updated Mods:
Brode UICP w/ Greddy Type-S
Joe P-MBC @15lbs
Injen Intake
K&N Filter
3" Down-Pipe, Test Pipe
3" Cat-Back
MagnaFlow Muffler
ACT 2600
XACT Flywheel
Ported o2
NGK Plugs and Wires
Walbro 190fp
Best of the night was a..
[email protected] with a 1.859 60ft
Best 60ft of the night was a 1.858. Still bogging. Need to practice more on the clutch.
Best MPH trap of the night was 94.76
This was all just on 15psi, 92 pump gas. I still need to practice launching at the track. I hook so well I bog...alot. On the street I roast the tires and no bog. So more track time I should be dipping into the 1.7 60's on street tires and pulling a high 13.
Not bad for a basically stock 2g :D
Updated Mods:
Joe P-MBC @15lbs
Injen Intake
K&N Filter
3" Cat-Back
MagnaFlow Muffler
ACT 2600
XACT Flywheel
Ported o2
NGK Plugs and Wires
Walbro 190fp
That stock turbo is killing your top-end. If you are only traping 94 MPH. When I trapped my high 13, my top end was falling off due to a overflow problem with the FPR. I should be mid 12's now, can't wait to get back to the track. If you were to just upgrade to a 16G it would help tremendously. Good for the stock T-25 though.
I have a tdo5h 20g sitting at home. I am waiting to buy some 650's, 255lph fp, and a way to control it. Then I will upgrade to a Supra SMIC for the time being on low boost until I get a FMIC.
That trap speed is kind of low, theres a guy on here with fewer mods that ran a 13.7@97mph.
