13b turbo question
2g_spyderturbo
222
Oct 29, 2003
chicago, Illinois
Ok first i feel pretty stupied for asking this,but i couldnt find anything on it.
ok i have gotten a free 13b turbo from my buddy and was woundering if i need anything to hook it up to my 2g.I know about all of the other turbos and what you need,but what about the 13b? If i do need somthing can you post a link to what i need.
Thank You
John
^^^well thats not what i asked. The only reason im putting this on is because my t-25 took a dump on me
thank you awdtalontsi1992 i wasnt to sure abought that
The 13G used a different coolant line then the 14B. So make sure you get the appropriate one, and banjo bolts.
You guys all need to read a little more. His t-25 blew up on him, and he got a FREE 13b to use until after christmas when he is going to install a 16g. The install kit he is getting now is basically just going to make his change to a 16g from the 13b even quick(mostly because he has already changed the turbo once, and the bolts aren't old and rusty). You need the regular install kit for a 14b/16g setup on the 2g, with a different coolant line made for the 13b, so make sure you get the right line. There, summarized it all up.
  • Wanted 6 bolt NT water pipe
    • chrisman287
