100mm eagle crank?
what mm stroke is the stock crank? why is eagle way to much for me? thanks
88mm is the stock stroke
The eagle crank is too expensive for what your goals are. As another user has suggested, just find a working 2.4L bottom end and put your head on it. This will get you somewhere near the 165hp mark.
It will be fine as long as you don't boost it.
wow if i just put a 2.4l bottom end on my car and put my head on it i will get about 165 hp with all stocl stuff? thats mot bad at all. what car do i get this block from? thanks
