#1 cyl missfire... HELP!!!
Renagade
58
Mar 1, 2003
Houston, Texas
ok, the car idles like s*^%, and acceleration down low in 1, 2, and 3 is very jerky... power kind of surges. Now mind you this is casual driving. I put the power down, its hardly noticable. i have a CEL, and the code brought back #1 missfire. so... whats up???:confused:
Check #1 cylinder spark plug, wires.
Check the coil too, while you're at it.
plug appeared "lazed" cleaned it with a brush wheel, no real noticible difference, thought about plugs and wires... but if it was the coil, wouldnt i get get missfires on 2 clys?
I had the same problem. Code "misfire #1" checked coils and injectors OK. Replaced plugs and put on Magnacor wires. thought I had a new car.
yea... my first plan was NGK irridum and magnacore 8mm.
after that, not sure, i have a minor fuel problem now, but thats another story, this is actually causeing damage, and a lot of aggravation!:thumbdown
I think the wires were the problem, cause the plugs looked ok.I put in Bosch platinum+4 cause they were the best I could get locally. I still had an intermitent miss. when ipulled the plugs i found the Bosch were about 1/4" shorter than the stock NGK's and the wires were not making good contact on the plug. So i've got stock NGK's in it now. Try wires first.
well i got ngk irridums, and 7mm wires,she runs real strong now, and smoother then ever before, thanks everybody.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
