Help with missfire!!!
Boostedexcel
133
Sep 22, 2005
hidden hills, California
help, something is wrong with my car. I had the car apart for a while because I had to change out the O-ring on the main water pipe. Anyways I get everything back together, start the car up, let it idle(only had around 15 Hg), drive around the block, boosted it and got a 25 lb spike!!! Kinda scary with my 16g on stock fueling. So I drive around for a couiple minutes, get gas, and then the car doesn't start...get the car jumped and now has a bad miss and again died when I got home. What could be the problem:
-Bad alternator or blown fuse
-fouled plug or bad wires
-hole in piston after the huge spike
-vacumn leak
Any suggetsions?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
