Silversurfermd
- 2
- Oct 13, 2007
Beaverton,
Oregon
Hey there. I just finished rewire walb 255 with Fuel Lab filter/6AN line and FPR. Tried 650 injectors but had a problem with tune and replaced back the 450 injectors.
Now I have a misfire and carbonized plugs 1 and 3.
Fuel pressure is set at 43.5 with no boost leaks. I can hear the misfire in the block before it exits the exhaust. I read this can happen in "rich conditions" but my wideband says I am lean? If rich, shouldn't all plugs/cylinders have soot? Fuel pressure reads normal?
Thanks for any help...
Fuel pressure is set at 43.5 with no boost leaks. I can hear the misfire in the block before it exits the exhaust. I read this can happen in "rich conditions" but my wideband says I am lean? If rich, shouldn't all plugs/cylinders have soot? Fuel pressure reads normal? Thanks for any help...
