FadedBlue
- 51
- 0
- Feb 24, 2013
Mineral Ridge,
Ohio
Hey guys brand new DSM owner here, its a 94 Eclipse base 1.8 just bought it today and looking to learn a bit more about it. I plan on changing the oil tomorrow along with the fuel filter, which it needs bad, from the maintenance records the oil was last changed around 227,000 miles its a little over 230,000 now so I think its due for that. Anyways before I change the oil I was thinking about running some seafoam through to clean it out I have seen it done on other cars is it the same with DSMs?
When the car is in neutral the oil light comes on and the oil pressure gauge is at the bottom what would the cause of that be?
Are there any aftermarket temp gauges that I could use since the stock one isn't working properly.
On to my main point this car really needs some more power, I don't need it running 10s or anything like that but I at least need some get up and go power so I'm assuming the basic bolt on mods such as intake, exhaust, and throttle bodies will help me out?
Finally what can fit in the rear hatch? I have a set of orion subs from my old neon that I plan on putting in I haven't checked to see if they fit yet, they are 12" XTRs, also what size are the stock speakers? I have pioneer 6x9s and Kicker 6" door speakers also from my old neon.
