1G 1.8 injector CC
The reason what color are the injectors was asked.....is because that's an easy way of determining what they are....blue top, black top, red top, orange theirs a diff. color for every model, answer that question and we might be able to help you a little more.
and sorry DSM1G90 I had to do it i sat and laughed for a minute about that.
edit: if you had 390cc injectors in a nt it wouldn't have ran, it would have flooded every time you tried to use the throttle. More than likely you have a set of Red top 240cc injectors that have faded to the same color as the 390s, stock the 1.8 comes with a yellow or clear top 210cc injector
(shouldn't be typing when I was dog-assed tired ..LOL - I deserved that for not proof reading.. s'alright)
Yellow's are 510's. True, hit a yard and I bet you can pull yourself a set of injectors for cheap. Just that you'll have to get a new set of both "o" rings and injector seats for the injectors.
Thats weird because the damn thing ran really good with them and I KNOW they where 390's because I read the side of them
I have never seen a stock NT run on those higher Injectors....I Tried it....Ive only seen it done one way through a High Compression Motor and I built it>>>
http://www.dsmtuners.com/forums/hangout/356681-videos-1g-high-compression-build.html#post152084063
At any rate what your looking for is a Yellow or White Top 210cc Injector
DSM Graveyard - Your #1 Source for DSM Parts!
$8.99 a pop
Here is what you say you have.....Note what it says.
"This is a Used 390cc Fuel injector, found on the 1G Automatic Turbo Engines."
Also, No one started blurting off crap that couldn't help you....You were told in the very first reply what you needed, and asked about the color so that it could be certain you were given the right information. Somehow another you started arguing about the sizes of the injectors.....
