02 sensor
fwdturbobov1996
1,504
8
Feb 27, 2004
Blue Springs, Missouri
anyone replaced there o2 sensor yet ? the one behind the cat ? if so , how do you get up into that 1 inch hole the wire is running into . ?
replaceing your o2 is pretty easy its all pretty much just plug and play.... just unsrew the old one put a new one in and hook it up thats all there is to it :thumb:
95-96
upstream - OE# 4606037 / Bosch# 15704 / Standard# SG203
downstream - OE# 5269711 / Bosch# 13417 / Standard# SG211
97-99
upstream - OE# 5269744 / Bosch# 13399 / Standard# SG315
downstream - OE# 5269711 / Bosch# 13407 / Standard# SG211
part numbers if anyone need um :thumb:
on my 95 tsi awd I was able to pull the rubber plug out of the bottom of the car and then the connector was right there and it just unplugs.
now the question is, for anyone who knows for sure. can you put the o2 sensor in from the trap door or do you have to do it from under the car?
