CRiXman
- 76
- 0
- Nov 14, 2004
Vaud,
Europe
Hey Guys & Gals,
I just received a GTECH Pro SS I ordered. I did a few test runs from 0-60 and got results in the 8.2/8.3 seconds..
(this confirms the stopwatch readings I was getting before the GTECH). I know a stock 96 GSX is supposed to do a 0-60 in like 6.5 seconds.
Could this be a result of a boost leak (this is my first turbo car)???
What do I feel when I accelerate??? Well:
For the sounds: I can hear a slight whistling noise as I accelerate. I have been thinking this is just the turbo spooling up? Is this correct or am I hearing a leak?
For the feeling: First gear is great, the acceleration feels almost rocket like.
but from the second gear on-wards, it pulls but much less than the first gear, (not enough for my taste). Same for third... <--- This diagnosis is during a 'heavy' acceleration. However... if I am driving calmly and I am on 2nd gear, and suddenly I want to accelerate the Car pulls significantly harder than it does on on 2nd gear during 'heavy' acceleration. Is this a typical boost leak?
Also for your info on how I launch.. I rev up-to around 3.5k - 4k during stand still and then let go of the clutch slowly giving gas and shift gears at around 5.5k..
..For the moment I am completely stock, no gauges even...
I would really appreciate if someone could gimme some expert advise!
Thanks!
C.
(this confirms the stopwatch readings I was getting before the GTECH). I know a stock 96 GSX is supposed to do a 0-60 in like 6.5 seconds. Could this be a result of a boost leak (this is my first turbo car)???
but from the second gear on-wards, it pulls but much less than the first gear, (not enough for my taste). Same for third... <--- This diagnosis is during a 'heavy' acceleration. However... if I am driving calmly and I am on 2nd gear, and suddenly I want to accelerate the Car pulls significantly harder than it does on on 2nd gear during 'heavy' acceleration. Is this a typical boost leak?Also for your info on how I launch.. I rev up-to around 3.5k - 4k during stand still and then let go of the clutch slowly giving gas and shift gears at around 5.5k..
Thanks!
C.
