Street Build ITFLYS - 1Gina2G
ITFLYS - 95GSX 2.0L 6-Bolt Crank with 2G pistons, 1G TopEnd, with 2Gb-CamSensor and a Kiggly-CrankSensor - TD05H-Bastard 20G - E85 w 1000cc inj. ~25psi. Street driven track day car.
Gonna try this - wove ends of bare copper together and then flowed in some solder, trimmed down to a smooth ball, insulated and covered with a tough sleeve where the oem metal bracket could eventually go.
ready to install
Drilling out bolts is my favorite thing!
Harness ready for mock up so I can get the final length on the plug wires. The only thing left in my way are 2 snapped off bolts - the one I really need out is on the knuckle.
I’m feeling confident after reaching the M8 tap size 17/64 hand drilling with an old corded drill. I had a metal gasket to shield the axel boot from errant drill bits, and it saved me 3 times.
I started the work of setting the tap to work, with the sensor in place to ensure tap position and alignment. I got the tap to start and backed it out and removed the sensor. On putting the tap back in, finding the initial threads, I started to crank. After a few turns, I’d back it out to clean it and oil it
Then- snap - horror - disbelief - pleading - sadness, and frustration all in the span of 10 seconds.
and all attempts with pliers, and a well placed punch and tap with hammer yielded no reverse out progress. sofa king … bleh
Then- snap - horror - disbelief - pleading - sadness, and frustration all in the span if 10 seconds.
They make a tool that slides down the flutes to remove them. Assuming they're not stuck. Maybe a few well placed pins could do the same?
While I wait for an extraction tool to arrive, I was able to successfully drill out and tap the other snapped bolt. No hits on to the classified add looking for the brackets. The search continues.
Nope, ABS light still on after test drive - so I started trying some things from this document:
The diagnostics PDF outlines different methods for pulling codes depending on FWD vs AWD. The sweep meter method for AWD did not work for me - I turn on the key, the ABS light does its rapid flash 3 times? - and then off for a moment, then on solid. Using the volt meter between pin (8 and 4-5) results in a constand 11.5v as soon as the key is on. No codes revealed that way. I even tried grounding pin 1 and then turned on the key. This turned on the ABS light constant as soon as the key was enabled. The ABS light says on, until I disconnect pin 1 from ground - then the abs light flashed 3 times? and I could hear relay clicks - and then it comes on solid again.
Gonna have to go component by component, starting at the ABS computer in the foot well. (I suspect the pump) If the wiring to the corners and relays check out, maybe I'll learn how to manually try to engage the pump to see if anything is moving.
I think the Bosch sensors are probably not going to work in the end. I'm reading that the nippondenso system cutover to Bosch in 95 was a completely different sensor. The Bosch sensors I have probably won't work.
Project creep, Nippon abs ltd wheel sensors cannot be found. The sensors I have are for the Bosch ABS system that was installed with late 95’s. finding a bosch control module for cheap was easy. Finding a Bosch ABS pump is possible. The chassis wiring is different. The hardest part, switching the wiring and plugs.
Yay. Have you seen mine? Here it is. I have the same alternator on the car now that I put on it here in 2019 and haven't had to change or repair anything about the heat shield.
Thanks for the link...Ive been wanting to do this but keep passing it by because I was too lazy to make a template.
I suppose you might need a different shape to work on a 2g but if you want to try my template for something to start with, that scan in post #2 prints out to about 1% accuracy on 8.5" x 11" paper. You can check it in both directions with a ruler of course.
I looked through my pics again to find one most worth seeing that I didn't post yet. I think this one, which is shot looking more-or-less straight aft and is all squared up with boxes and a scale, and was shot with the most telephoto my good lens can do (35mm equivalent focal length of 105mm) to minimize wide-angle distortion. So you can get a better idea of the angles and how far inboard it goes from the PS bracket that it bolts to.
I suppose you might need a different shape to work on a 2g.
Its a 1g in a 2g, so should be close if not spot on.
Been enjoying the fuel economy of E85. Never thought this 105 octane bullet would be cheaper to run than my wife’s Hybrid Rav4.
I thought for a long time that it was an either/or commitment with E85 which kind of scared me off since I have to do the cold weather thing, but since you taught me how to do base tunes, I think im going to start going that direct for the summer months... and just fill with 93 for when the car sits in the winter.
  • For sale 2g Black Box ECU
    Known working and Good Black Box ECU out of my personal 1998 GST. This ECU is completely stock...
    • JayyDSM_
  • For sale 7 Bolt 4g63 Bare Block For Sale
    7 Bolt 4G63 Block With Girdle And Oil Pan
    • LSM
  • For sale 420A Valve cover
    Powder coated candy red , used $60 located 91321 Santa Clarita California Can ship
    • Stizzydrew
  • For sale 4G63 Antilag coil on plug, m&w ignition box, wilson Billet 90mm throttle body,
    I’m upgrading to fuel tech so I won’t have used for these parts I’m in the middle of a build and...
    • aguiga
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
