1G 6 bolt starter 7 bolt starter differences?
chanley talon
20+ Year Contributor
773
14
Nov 10, 2005
Spencer, Indiana
I could not find the proper forum to place this question in so i put it here for now.
My question is. Is the 6 bolt 1g turbo starter different from a 1g 7 bolt starter? This gets really confusing because they put 6 bolt motors in early 1992 then mid year switched to seven bolt cranks? I need a starter i have a 6bolt 1992 and heck i can not for the life of me get the correct one? If you know the answer too this question please help if not don't reply. I just want knowledge . The part number is 1991 are all the same for manuals and automatics! But in 1992 they give you a option manual or automatic. Then they have a different part number? So there must be some type of difference? I'm thinking its the 6bolt to seven bolt crank swap?
i think they are the same but im not 100% sure, i know the plate between the trans and block are different
Here's what i have found the 6 bolt starter or manual and automatic pre 1992 back has a longer snout it goes deeper into the transmission. The 7 bolt seem to have a short snout when it comes to a automatic . When they switched the cranks in mid year to 7 bolts the manual kept the same length snouts but the automatics became shorter snouted.
Okay heres a picture i took. On the left is a 1991 awd starter manual or automatic same part number in this year 16939. On the right is a 1992 awd automatic starter you are given a automatic option in this year part number is 17217. However this starter would not even touch the flywheel on my 1992 awd why not? Because it is a 6 bolt crank. So i need a photo of a 1993 manual and auto starter. Or there part numbers.
17 years later you are my savior. My starter would intermittently not start my 1992 Talon when I bought it, so I got a new one for the 1992 talon auto only for it to suddenly stop cranking my engine leaving me stranded at a parking lot (and with no way to get home from uni after). Will update if the manual 1991 starter works, since I ended up putting in the one I had in there before and just praying it cranks eventually. I can't really find a listing for the 1991 starter automatic.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
