ZachTSI95
- 5
- May 4, 2026
Oswego,
New York
Looking for Education and advice. 95 Talon TSi
Recently aquired a Talon on trade, posted it for trades,offers because i have no idea what its worth as a car in general but started to fall for it.
Got the car not running with most if not all the parts to get it to be a running car again inside of it
Owner said the motor was rebuilt and built for nitrous, appears to have defiently been rebuilt from the outside or atleast torn down as every gasket and plug i can see appears to be brand new, the manifold was changed to one with a waste gate, ebay turbo, aftermarket intercooler, has a nitrous bottle and all the hookups for it(cant seem to find the particular kit for this car unless thats a stock intake with a sticker or something). Said theres a new clutch in the transmission.
Head has been replaced with a 97 head
Driveline is off and in car
Cv shaft under passanger side was broke
Multiple sensors/starter wasnt plugged in
Exhaust is unhooked
Strut tower needs repair and so does trunk floor
Camshaft sensor wires were cut and spliced into a sensor that goes to the boost lines, see inbetween the valve cover and the billet fuel rail.
Ive checked the timing marks since the cover was off anyway, belts on and its all lined up, turned car over by hand feel the compression stroke, no binding or hard spots
My question is where would you all of the DSM community start, what to check and double check before trying to crank or do anything too crazy
Just and edit, the starter relay is trash on this car(apperently a pretty common problem from what ive seen) so thats bypassed, so dont need the clutch to start the car anymore either and the key works for that, however the starter was no good so i got a salvage yard starter and that also was no good so im ordering a brand new one,
I also have already removed the 97 camshaft postion sensor/cam angle sensor and built a plate to bolt over it, aince the car doesnt need it
Exhaust is unhooked
