Ralph-RaccooN
- 6
- May 23, 2026
ON, Canada
Im fixing a 1989 Dodge 2000 GTX, its a Galant with the non turbo 4G63.
anyway I have some new rings and its been going though following the factory service manual. compression rings are perfect.
but the oil control rings are over the limit of 1mm, the old factory ring while no longer springy has half the gap.
Factory defect? what would be better, to run the original rings with less spring or new rings with large gap?
here is a pic, oil ring on top, new ring on bottom. the second grove rings were also packaged as grove 3 rings.
