steve
DSM Wiseman
- 17,218
- 3,876
- Feb 3, 2002
St. Charles,
Illinois
Unclear while running, you do get the normal startup CEL if it drops low enough to reboot. Your Cam Sensor fault doesn't sound like a power issue but we haven't made much progress so far. I'd really like to see what the ECU is seeing when your trying to start and it won't.
Is there some reason you don't want to share a log file? There might not be anything sigificant in it or it might answer what's going on.
Can you clear the fault and get it to start right after?
