02 sensor dump on an internally gated turbo
RoadRunner2g
3
Dec 19, 2025
Ballwin, Missouri
So I have an scm6152 turbo that is internally gated. I plan on keeping it internally gated, but I wanted to get an o2 dump instead of having it recirculating the exhaust gases back in. I already found the kit I need, but I just want to make sure I don’t have to retune the car cause there is almost no tuners where I live. I plan on eventually learning to tune the car myself tho
Assuming no leaks, the ratio of air to fuel in the exhaust will be the same at the back of the exhaust valves, exhaust manifold, turbine housing, o2 housing, downpipe, etc. The wastegate just diverts the exhaust around the turbo's turbine wheel. If you decide to dump that exhaust instead of recirc it into the downpipe, the ratio of air to fuel is still the same to the sensor, there would just be less volume of it.
I'm honestly not sure on the behaviour/importance of the rear O2 sensor in the eyes of the ECU, but it is definitely just along for the ride exactly like the front sensor when you're in a situation of the wastegate opening as you're in openloop (the ECU ignoring it).
tl;dr: No.
tl;dr: No.
Ok perfect, thank you very much for helping!
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
