SixBolt_16G
20+ Year Contributor
- 1,059
- 1,048
- Nov 7, 2005
Illinois
Throttle body stuff...
900 RPM is your target and you get close. Your log shows low coolant temp (145deg). You can't evaluate your idle targets and ISC position until after the engine is fully warmed up - 180-200 deg.
I closed it all the way (I did not use a block off plate) because I think the walkthrough I followed says that it would create a boost leak if I didnt. I did also reroute the coolant hoses from the throttle body. Havent had any problems with stalling and havent needed to give it gas to keep it running.Normal cold start is a high idle point up to 2000rpm, and then the FIAV slows things down as the temps warm up. You modified the FIAV start point to close it down so you may not hit 2000rpm cold anymore. The FIAV start point needs to be open enough to start without dying. Usually people close down the FIAV after all leaks are addressed and when you still get cold starts higher than 2000rpm. Closing down the FIAV start point too much will cause you to need to hold the throttle plate open when cold.
So i did follow this method. I disconnected the battery so that the lrndidleadj would be reset to 144 and then turned the BISS til it was around 30 while the car was at operating temp with no electronic or the fan running. Cant remember if I had done that for the previous log, maybe it will be reflected in this new log. If not, I will try again. I remember I had some problems with trying to get a steady 29/30/31 because it kept wanting to dip down towards single digits. But I didnt do the base timing lock that youre recommending so i will try that. But I did actually get it to hover around 30, so i thought i was alright.Setting up your TB.
The ISC (when the ECU is in closed loop mode) will try and hold your RPM target, but it has a narrow range, so the BISS and FIAV need to be close.
When the temps are warm, your ISC target position should be about 30. Adjust your BISS when warm until it holds 30 at your target RPM. I recommend enabling the diagnostics feature in ECMLink that holds the base timing at 5deg when setting the BISS for ISC position 30.
I think it might be the cable itself that is sticking. I followed pretty much the same procedure that you described. Ive tried adjusting it both when the car is hot and when its cold. Sometimes the adjustments made the hanging rpms slightly better/worse.I like to have all the cable slack on the closed side of the throttle plate range. Do this by loosening the throttle cable position, and then jam the accelerator to the floor. Set the throttle cable position to hold the throttle plate open against the full open stop with the accelerator all the down. This will prevent you from breaking your throttle body jamming the accelerator to the floor.
1. I thought the need for holding the throttle during warmup was only if both the fiav and the isc were both blocked off, no?
2. The car still seems to warm up as usual, but does starting the car at a lower rpm eventually cause other issues? Seems like it is being given more gas on start up to run rich, without the RPMs to justify it. Not sure if or how much that matters.
Yes - when the idle is stable, the isc stops moving aroundSo i did follow this method. I disconnected the battery so that the lrndidleadj would be reset to 144 and then turned the BISS til it was around 30 while the car was at operating temp with no electronic or the fan running. Cant remember if I had done that for the previous log, maybe it will be reflected in this new log. If not, I will try again. I remember I had some problems with trying to get a steady 29/30/31 because it kept wanting to dip down towards single digits. But I didnt do the base timing lock that youre recommending so i will try that. But I did actually get it to hover around 30, so i thought i was alright.
3. How do you tell in the logs that the ISC isnt set correctly since that number seems to move around constantly when i look in my logs? Is it suppose to settle at 30 for an extended amount of time during idle when it is set correctly and just move around when you give it some gas? I dont know that ive ever viewed the logs of a properly running car to know what normal looks like.
Yes that is it4. Is this the setting that you are referring to that holds the base timing at 5 deg?
A sticky cable will cause high idle hang. You will know its the cable if there is no slack and you can resolve the high idle by manually closing the throttle plate by hand. If the cable is totally slack with a high idle, then you need to see why the plate is sticking open on its own.I think it might be the cable itself that is sticking. I followed pretty much the same procedure that you described. Ive tried adjusting it both when the car is hot and when its cold. Sometimes the adjustments made the hanging rpms slightly better/worse.
A few other reasons why Im suspecting the cable:
-Throttle body was rebuilt a good number of months before the rest of the work was done and I didnt have the hanging rpms issue. Drove the car every weekend within that time.
-Throttle position goes from 0-100%
-TPS goes from 0.63 to 5.00 when stepping on the accelerator pedal.
-Throttle cable is the new piece that has changed. Was bought new, but sitting in garage for about 8 years. have a replacement here that im going to try swapping out.
-If I physically step on the accelerator up to 3000 rpms and let off, the revs will come down to about 1500 or so and hang for a second or 2. Consistently. If I rev at the butterfly, it never seems to hang. It seems like when I step.on the pedal, cable is too long and doesnt snap the pedal back into position, like the cable never gets tight enough on the pedal side.
Nope. Not II looked at your speed density map, and I have questions.
Did you make this map?
Yeah - its not tuned. Whatever they were doing with ECMLink, it wasn't finished. I can help you get reset.Nope. Not I
Ive mentioned a couple of times through the build thread with the more recent posts, that my car was at a shop (One that actually deals with DSMs/Evos frequently) and they screwed me over for reasons unknown to me. Their tuner was suppose to come back out and do a few more things, but the shop got frustrated with the car breaking on the dyno (clutch and fuel pump), interactions between me, them and the guy they have tune all the Mitsubishis. I showed up one day to supposedly pick up my car because they told me i would be ready, but instead they blew up at me for coming there after keeping my car for 7 months. I am unsure as to how far the tuner actually got which is why I have the #7 description of problems that Ive started all of these post with 7. Unsure how much of the tune was actually finished. That is why Ive been doing all the work myself to get it running well again.
Only things Ive ever really done in ECMLink is view logs and set the idle in the past, but even I can tell that there were some questionable things going on with it.
-None of my inputs were set
-My wideband works in the car, but wasnt set up to log in ECMlink.
-My airperrevs are high at like 0.40+ while idling
-Fuel trims look to be running rich
This is why I was trying to focus on fixing the low start up rpms and hanging rpms before i start asking people for help with tuning it. Because frankly, I dont understand how they did any tuning at all with all the boost leaks Ive fixed so far or with the rpms hanging between shifts, especially getting anywhere near boost.
