- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Automatic
- Mods-Bolt-on
- mhi evo3 16g, 510cc injectors, high flow fuel rail, Dejon hard intake pipe W/ K&n filter, boost gauge, NXS MBC, Punishment J-pipe, Cx racing FMIC and Punishment hard IC piping W/ greddy style BOV, DNA alum radiator w/12" efans, DNA Tubular manifold, DNA 255lph W/ DNA afpr, Atmospereic dump o2 housing, 3" Megan downpipe, Punishment 3'' test pipe/catback, Silicone vac and radiator hoses, spark tech coil-on-plug setup, prothane motor mounts, clear cam cover
- Mods-Engine
- Block honed and blueprinted, knife edged eagle crankshaft, 2g pistons on 6 bolt rods, new rings, bearings, waterpump, oil pump, balance shaft eliminated, arp headstuds, adjustable cam gears, gates racing timing belt
- Mods-EMS & Logging
- M105 logger, type R boost gauge, water temp, oil pressure, adjustanle fuel pressure regulator
- Mods-Drivetrain
- F1 stage 3 clutch and Pressure plate, Short shifter
- Mods-Handling
- 16" enkeis with 215/50 yokohamas, drilled and slotted rotors all around with ceramic brake pads
- Parts Wishlist
- DSMLINK
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
