Activity Feed
Live updates
  • xiprometheus replied to the thread Power Drain after new Alternator.
    · 4 170
    Thanks for all the help so far! I tried to use my friends multimeter but his was not working so im going to borrow one from work. In the meantime i am going to check the fuses and fuse box too see if theres anything loose/corrosion. Im thinking i...
  • jesse12345 replied to the thread 98 Eclipse GS high school dream build.
    · 45 3,245
    My curiosity got the best of me and I just had to yank the side skirt. I knew the rockers were bad but I didn't expect this level.You must be registered to see element.
    · 45 3,245
    It's pretty much a must on these cars, especially here in the rust belt.
  • Ludachris replied to the thread DSM Shootout 2026.
    · 41 1,680
    For those who haven't left yet, let me know if you want me to create a QR code sign for you to print out and display next to your car: You must be registered to see element.
  • Hi guys,Thank you so much for your help. This is incredible. The car is currently under eletrical maitenance and it's almost complete. I'm envolved in trying to print a latch gear that is missing so I can lock the car properly and I'm also...
  • ItsTwan309 replied to the thread 2G LC2 not reading in ECMLink.
    · 23 434
    I would start over. Download the LC2 instructions or see the ecmlink link I sent. Do not connect the wire Here is a snip of wiring from innovateYou must be registered to see element.
  • steve replied to the thread 2G Injectors not firing.
    · 8 189
    It's harder on a 2G to test the cam and crank sensors than on a 1G where you can turn the CAS by hand and watch the signals switch voltage. You need a good multimeter or an oscilloscope to see them on a 2G.Noid lights don't always work on our...
  • Hey there. 1st group buy participant here, so my review is mostly positive AFTER the EPS kit (versa eps). I tried driving it around without the EPS and it felt harder than running oem without the power steering. I sent my rack back to the...
  • jesse12345 replied to the thread DSM Shootout 2026.
    · 41 1,680
    I'm going to try hard to make it next year, ideally with the car but who knows at this point. I've never been to one so I'll be going in blind. Man I need to see all of these awesome cars.
  • HyeToki replied to the thread 2G LC2 not reading in ECMLink.
    · 23 434
    Thanks for the reply Yall!I am currently not home to check the wires at the moment, but I do remember how everything was plugged in, and I made an outline showing exactly how everything was connected.I also want to mention that the car was...
  • pauleyman posted the thread Im in minneapolis in The Hangout.
    Anybody want to grab a bite and beer I'm here for 2 days. As long as you dont mind 50 up Gen x company.
  • dgdsm replied to the thread Power Drain after new Alternator.
    · 4 170
    There are some simple tests you can do with a multimeter to check for alternator leakage current. I have a similar situation, I replaced mine in June, but with an older compatible OEM alternator. I took it to O'Reilly's after cleaning it up a...
  • 92AWDHX40 replied to the thread DSM Shootout 2026.
    · 41 1,680
    Locked up and headed out thursday morning in my daily to meet my friends with dsm, getting towed. This year he isnt making it hes head to germany but goal get it to run on stand alone. Everything should go as planned. Plan to meet up with some...
  • pauleyman replied to the thread DSM Shootout 2026.
    · 41 1,680
    We need about 5 guys and rent an rvI would never have thought it would grow like this. My first Shootout was 96 and if I remember it was 88 cars.
  • jdxnc replied to the thread DSM Shootout 2026.
    · 41 1,680
    I'm 13h each way and have done it 10 times now, it's not that bad.Unfortunately this year will not be one of them, things just not working out on my end, too little time and work too busy.
  • oldmanfrost replied to the thread 2G Injectors not firing.
    · 8 189
    Yes checked pressure.. that was the first thing that was handled. Given power from outside source. To jump an injector with the plugs out , while cranking and fuel sprayed out the cylinder.Okay, I will test those two sensors.
  • Sdcryan1 posted a reply to a question on the classified ad For sale 2g Eclipse/Talon Overstock from Partouts.
    yes they would. id like to just sell the set im not asking a ton for them 65 shipped each set. I think the inserts alone, new are more than that.
  • diambo4life replied to the thread DSM Shootout 2026.
    · 41 1,680
    We should. 16 hour drive tho....:toobad::toobad::toobad:
    · 41 1,680
    Next year. OKC caravan!!!
    · 41 1,680
    Been in this game for almost 30 years and I have never been to one. Maybe some day...
