Activity Feed
Live updates
  • chrysler kid replied to the thread 95 GSX / 97 GST Spyder.
    · 161 26,393
    Glad you figured it out. Some of the scanners have problems communicating with obd2a interface and try to auto interact to detect manufacturer or vin numbers and when that info comes back blank they just show no communication
  • CDgr97GSX replied to the thread 2G Fuel pressure fluctuation.
    · 62 1,596
    Unfortunately this one it's not possible to get it to Romania from Amazon.I have the option to deliver it to a friend in CA. He will help me out with shipping to my address. Instead the Omni Power have the option for international shipping and it...
  • chrysler kid replied to the thread 99 GST mechanical restoration.
    · 24 2,030
    You must be registered to see element.You must be registered to see element.You must be registered to see element.You must be registered to see element.You must be registered to see element.You must be registered to see element.You must be...
  • OMN_DSM posted a reply to a question on the classified ad For sale Part Out: 1992 Laser AWD.
    Yes I have it.
    Yes I have it all. Let me know your offer.
  • barza21 replied to the thread 1G 1991 Bouncing Tach.
    · 2 143
    Steve,Thank you for the reply and all the information. I looked at the wiring diagram for the 91+ cars (mine is a 91) and I see the condenser that you are talking about. I have replaced the coils with a new one while I was troubleshooting a...
  • GoldNugget90 replied to the thread ECMlink Speed Density Switch No Start.
    · 26 672
    Seems reasonable, I'll toggle some more (and still do the TPS voltage adjustment you recommended). I'd rather spend more time getting a better idle than rush it, doing my best not to blow it up.
    · 26 672
    Haha, Irish goodbye'd right outta there. Kinda weird, I have about 7 logs from the same time. 5 of them start fine and then taper to zero volts, guessing it's getting way too lean.
  • 1990TSIAWDTALON replied to the thread ECMlink Speed Density Switch No Start.
    · 26 672
    Thanks @SixBolt_16G
  • SixBolt_16G replied to the thread ECMlink Speed Density Switch No Start.
    · 26 672
    Your Front O2 sensor went to the bathroom at 7 seconds and never came back to the party...?
  • HyeToki replied to the thread 2G LC2 not reading in ECMLink.
    · 23 436
    Hey Steve, This good friend of mine is the one helping me out. Here is the log.Regarding the Color of the wire, My yellow wire from the innovate is connect to both my gauge and the white wire (rear o2).
    · 26 672
    I don't know if its been said but I sit in my car, idling, and play with the global first to try to get my LTFTs and STFTs close to zero. They never are so I reduce or add global a bit and look at my Ecmlink log that I am running and look at...
  • Evo_This replied to the thread Link G4 Link VR4x Setup and Features..
    · 14 2,442
    To @Malcalmstunt Great write-up, definitely helped on getting the configuration right and being able to start the car based on tips here. Hope you're able to come back and fill in more info.
  • steelcurtaindsm posted a question on the classified ad For sale Part Out: 1992 Laser AWD.
    Does it have this sunroof handle
    · 26 672
    Tried the global deadtime adjustments, from zero up to 100, at various different global fuels. This log is at 100 ms and -59.4%. Pretty terrified to go try and drive it in this state, but at least it stayed running >1 minute until I shut it off...
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 56 4,772
    I'm not worried about too much boost in general, I was just concerned the EBC wasn't going to get a perfect reading on port E and it would overboost accidentally. Just speculation and paranoia since my Eclipse is my pride and joy LOLI have yet...
  • 92AWDHX40 replied to the thread Street Build Project 1g (NBA DSM).
    · 399 61,385
    Oh good im glad you got something oh yes promising for me now i have everything in place. Same ecu, and custom harness.
  • victorgalant replied to the thread Venezuelan E33A.
    · 39 3,098
    greetings, everyone. About a week ago I was doing some work to the car, was nice, but i think I will be taking a couple steps back with this engine. When i first assembled it in may 2025, when the cam caps were torqued, the camshaft wouln't turn...
  • BTKai posted a reply to a question on the classified ad Wanted 2g 2g Automatic transmission mount part # MB911274.
    the one i got has "F4A2" stamped i PM'd an image cause i can't attach one here!
  • jamel16 replied to the thread Street Build Project 1g (NBA DSM).
    · 399 61,385
    And we have an update. Finally got a first start on the Haltech. Hopefully I can still make the shootout, but I still have a few more things to clean up. Next to dial in this idle and post start. I feel a little hesitation when I press the gas...
