Activity Feed
Live updates
  • HyeToki replied to the thread 2G LC2 not reading in ECMLink.
    · 25 862
    Hey Steve, This good friend of mine is the one helping me out. Here is the log.Regarding the Color of the wire, My yellow wire from the innovate is connect to both my gauge and the white wire (rear o2).
  • 1990TSIAWDTALON replied to the thread ECMlink Speed Density Switch No Start.
    · 45 1,348
    I don't know if its been said but I sit in my car, idling, and play with the global first to try to get my LTFTs and STFTs close to zero. They never are so I reduce or add global a bit and look at my Ecmlink log that I am running and look at...
  • Evo_This replied to the thread Link G4 Link VR4x Setup and Features..
    · 15 2,605
    To @Malcalmstunt Great write-up, definitely helped on getting the configuration right and being able to start the car based on tips here. Hope you're able to come back and fill in more info.
  • steelcurtaindsm posted a question on the classified ad For sale Part Out: 1992 Laser AWD.
    Does it have this sunroof handle
  • GoldNugget90 replied to the thread ECMlink Speed Density Switch No Start.
    · 45 1,348
    Tried the global deadtime adjustments, from zero up to 100, at various different global fuels. This log is at 100 ms and -59.4%. Pretty terrified to go try and drive it in this state, but at least it stayed running >1 minute until I shut it off...
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 56 4,994
    I'm not worried about too much boost in general, I was just concerned the EBC wasn't going to get a perfect reading on port E and it would overboost accidentally. Just speculation and paranoia since my Eclipse is my pride and joy LOLI have yet...
  • 92AWDHX40 replied to the thread Street Build Project 1g (NBA DSM).
    · 399 62,149
    Oh good im glad you got something oh yes promising for me now i have everything in place. Same ecu, and custom harness.
  • victorgalant replied to the thread Venezuelan E33A.
    · 39 3,225
    greetings, everyone. About a week ago I was doing some work to the car, was nice, but i think I will be taking a couple steps back with this engine. When i first assembled it in may 2025, when the cam caps were torqued, the camshaft wouln't turn...
  • jamel16 replied to the thread Street Build Project 1g (NBA DSM).
    · 399 62,149
    And we have an update. Finally got a first start on the Haltech. Hopefully I can still make the shootout, but I still have a few more things to clean up. Next to dial in this idle and post start. I feel a little hesitation when I press the gas...
  • dwb replied to the thread ForcedFour Time Capsule.
    · 56 4,994
    Good idea! It should be close to the turbo, so somewhere on the lower intercooler pipe.If you're concerned about too much boost you can always bypass the boost controller and run boost source directly to the wastegate actuator. On a stock...
  • GRNDSM replied to the thread 8.8 @ 165mph 2G AWD Gas Record.
    · 89 14,291
    Definitely a scary crash! According to this post, he is going to rebuild it.
  • Ludachris replied to the thread 8.8 @ 165mph 2G AWD Gas Record.
    · 89 14,291
    So sorry to hear about the crash @gastroker. Glad you're okay though. The video was tough to watch.You must be registered to see element.You must be registered to see element.May the car rest in peace. And may there be a gastroker II build.
    · 56 4,994
    Okay, so I've decided to just tap the intercooler piping and add a port. Less guessing, and I'm just more comfortable doing that. I bought all the stuff I need to when I was at work.Should I do it leading to the throttle body or on the other...
  • ItsTwan309 replied to the thread ECMlink First post! ECU question.
    · 54 2,592
    What does your ignition timing look like? I saw you said that you swapped the CAS. Did you set it?
  • ItsTwan309 posted a question on the classified ad For sale Part Out: 1992 Laser AWD.
    OE intercooler piping? Im changing a 92gs to a gst for my daughter.
  • pauleyman replied to the thread ECMlink First post! ECU question.
    · 54 2,592
    Doesn't really answer the question. Did your fuel pump assembly have a hose inside? Or a metal funnel thing with an oring. The latter are known to leak. If you haven't fixed fuel pressure that is still #1. What happened to MAF?
  • ArcticTsi replied to the thread Old School DSM & 4G63 goodness-Ads, Commercials, Tuning etc..
    · 592 83,560
    Can confirm this is the genuine article. Awesome that you hung onto this. Adding a pic for todays contribution. QC at the plant of a Laser.You must be registered to see element.
  • DP_52 replied to the thread ECMlink First post! ECU question.
    · 54 2,592
    I was able to swap the fuel pump with zero issues using a line wrench.Car runs better. Still had a rough idle. I did disconnect the MAF and it leveled out...Lastly, Do you have the link for the stock setting of the DSMLink ECU?
  • David199619 replied to the thread What did you do to your DSM today?.
    · 12,115 838,976
    Got my 98 gsx running and driving after sitting in the same garage for 10 years, only 100 miles put on in all that time. Last drove in 2022. Ordering some parts to fix things up. You must be registered to see element.
    · 56 4,994
    Okay, so port E is a 4mm, right? My boost controller is a 6mm line. I know you said that port E is boost only, but with the difference in diameter, would the pressure reading be consistent and accurate?Also, that port is part of the emissions...
