Activity Feed
Live updates
  • DP_52 replied to the thread ECMlink First post! ECU question.
    · 48 2,030
    Fixed both of those issues.Now trying to get the lines to the fuel filter off...The line from the fuel pressure regulator goes straight to a sensor that the previous owner relocated
  • Sdcryan1 posted a reply to a question on the classified ad For sale 2g Eclipse/Talon AWD Partouts.
    send a pm. I wouldn't like to, maybe we can work something out.
  • pat white replied to the thread What did you do to your DSM today?.
    · 12,064 826,676
    You must be registered to see element.
  • Does anyone have any close-up photos of the components underneath the knock sensor board on a 1990 EPROM ECU? I’m specifically looking for detailed photos of the components and traces on the PCB in that area. If you have anything like that in...
  • CDgr97GSX replied to the thread 2G Fuel pressure fluctuation.
    · 62 1,640
    I checked the AEM 3.5 bar sensor and honestly I don't like it so much, I have to use 2 adaptors and on top of that I have to do the wires too. Omni power is plug and play :)
  • We're on Boost replied to the thread 2G Fuel pressure fluctuation.
    · 62 1,640
    4-bar is kind of the ideal range, true. I wish AEM made their sensor also as a 4-bar. If I had to buy a 4-bar here in the US, I would get You must be registered to see element.. They are as far as I know the only place that comes right out...
    · 62 1,640
    AEM it's an option but I'm not sure what boost I will run so I can't say if 3.5 bar it's enough or not. I would say a 4 bar sensor would be the smart choice.
    · 62 1,640
    It seems I miss calculated the inside diameter, I always have to convert to mm. :) I'll buy one of this adapter, I've seen them on STM or Extremepsi website and once I have the pump out i'll try it. If I can keep the same length of the whole...
    · 62 1,640
    In here it's usually agreed that the AEM stainless MAP sensors are the best ones and the most reliable. They are round barrel type. You must be registered to see element.You must be registered to see element. if you aren't going to go over 35...
    · 62 1,640
    No, 11mm is the OD of the outlet pipe. Depending on where you look, the outlet pipe is either given as 11mm OD or as 3/8" Hose barb. It's made for 3/8" hose. Nobody gives an ID for it. 1g users in here have been putting 3/8" hose on it. Take...
  • diambo4life replied to the thread Awdmonster drag car.
    · 239 39,352
    Ok........I finally gave this build a real read from START to FINISH. Dayuuuuummm Frank, you have the patience of a saint! I totally know how it feels when you never want to give up! Looking forward to the new setup. You also got me scared about...
    · 62 1,640
    A fuel tank adaptor it's 3/8 which is 9.5mm. The inside diameter of the outlet of the pump it's 11mm. This was one of the reasons I didn't mount one. Also using the fitting and connect the pump with a hose and clamps the pump will be lower in the...
    · 62 1,640
    Thank you guys for pointing out something I didn't notice. At least it does make some sense now. It's a +10 years sensor, even though doesn't have so much working time. It's a Mitsubishi style bought it from extremepsi and I used before on stock...
  • NEVER assume the head is clean when you get it back. Sit it on something clean and move it around violently. See if any shaving come out? At the least, blow out all passages with compressed air or wash out all of them if in doubt. 👍
  • diambo4life replied to the thread Street Build Project 9s: Street Driven 98 Eclipse Auto.
    · 138 21,126
    Good deal. We are all here to learn. Been messing with these cars since the Clinton administration 😂 and I'm always learning something new....🙏🙏🙏Today I replaced the thermostat housing gasket, I was only using rtv there and it has been slowly...
  • dwb replied to the thread ForcedFour Time Capsule.
    · 56 4,792
    On the throttle body next to the P port.
  • tschuhly replied to the thread 2G stuck in limp mode.
    · 74 2,745
    Just switch out my oil pressure sensor and I didn't in fact have the connectors reversed...I can't test it yet since my car still hasn't been fixed but I'm sure that's what was causing the flashing dummy light.
  • heresjimmy42 posted a question on the classified ad Wanted 2g Finish My Project!.
    I've got a couple slim radiator fans if you need them
  • heresjimmy42 posted a question on the classified ad Wanted WTB 2g half rad.
    I have a half rad with the fan mounted too it. It came with my car when I bought it as far as I know it doesn't leak if you want to take a chance on it I do like 50 bucks plus shipping
  • opn0 replied to the thread ForcedFour Time Capsule.
    · 56 4,792
    Yeah that makes sense. Once I get some cash aside I'll get a better gauge.As for the E port, where is that one?Yeahhhh... That's why I was so confused when the 6mm BOV hose was T'd to a 4mm heading to that port. Dunno why PO did that but...
