Activity Feed
Live updates
  • dwb replied to the thread 2G Oil leak.
    · 39 371
    How about the pcv valve? Good working order and not clogged?
  • TasosEclipse replied to the thread 2G Oil leak.
    · 39 371
    Free flow only one line to take it back and down
    · 39 371
    What is your crankcase breather attached to? Does it flow free?
  • steve replied to the thread 2G Crank no start.
    · 5 131
    If you have the cable you just need to go to ECMTuning's web site and download the client software. You must be registered to see element.The 2G DSMLink V2 would loose it's tune if the ECU lost battery voltage so you'll need to find an old log...
    · 39 371
    They weren’t covered in oil they were just black . I know thats why I wrote here to hear someone else if it ever happened to another one.
  • Anfurnyy replied to the thread 2G Oil leak.
    · 39 371
    Black and covered in oil are kind of different things. And I get you changed the valve seals but obviously something is still happening.
  • jabo97gst posted a reply to a question on the classified ad Wanted Left / driver quarter panel glass for 2G Eclipse.
    how much sir?
    · 39 371
    When I took off the spark plugs they were black and the valve seals I change them now.
    · 39 371
    Smoking on decel usually means valve seals. The vacuum inside the engine / intake ports is pulling oil vapor through the seals. Could also be valve guides as well. Can you check inside the intake and exhaust ports and look at the valve stem and...
  • DSMPT replied to the thread 2G Oil pump timing.
    · 6 119
    If you have the balance shaft belt (the small one) you still have the shaft. Like Bobby said above, if the LH shaft has been eliminated, you can't feel centrifugal force by the balance shaft counterweight when you spin the oil pump sprocket...
  • FIBA M - EC17PSE replied to the thread 2G Oil pump timing.
    · 6 119
    You can check the rear BS bolt plus on the back of the block as a way but also if you spin this without a belt on it you can generally feel if the BS is connected or not due to how lighter the sprocket is to rotate vs with the original balance...
    · 39 371
    Please help I checked everything…
  • 4g63Sneaky replied to the thread 2G Oil pump timing.
    · 6 119
    I bought the car about 6 months ago. Is there anyway of knowing if the balance shaft was eliminated? Also would it be okay if I just set the time for the oil pump cause right now as it sits everything is in time except for the oil pump?
  • MindBlowin03 replied to the thread Weekend Warrior - 1997 Talon TSi AWD.
    · 45 5,070
    Finally had some time to pull the trans and dive into it a bit. Pretty much what I expected, stripped second gear and broken 1/2 shift fork.At this point I'm pretty sure I'm going to go with a PAR straight cut synchro set. I have a spare built...
    · 6 119
    They have a different part number, so it would depend which one you buy. Original is what I said above.
    · 6 119
    All come with an arrow now from Mitsubishi, building and engine for a customer and his OEM pump uses an arrow and is a 7 bolt also just to note.I have seen both but most of the 7 bolts I have noticed are arrows my old OEM pump
    · 6 119
    The blue circled dot on oil pump sprocket is the timing mark for you. The early oil pump sprocket comes with an arrow, and the late sprocket comes with a dot. So in the pic, it's off, but keep in mind that all timing marks (cams/crank/oil pump...
  • Joh_ecp97 replied to the thread 2G Crank no start.
    · 5 131
    And to clarify I purchased the car with DSMLink v2 already on it. I have the cord for the tune from previous owner but not the physical disc or ECMTuning account info so I cannot access the tune even if I wanted to could anyone help me with any...
    · 5 131
    No, I have the cord to do so but I don’t have the disc or the ECMTuning account info from previous owner
  • pksystems replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,705 133,974
    Finished gluing the front section of bumper together. It looks pretty massive, but it is the correct size. I may change the route I was originally going. I was going to block sand the plug smooth, pull a mold off, and have 100% carbon body...
