Activity Feed
Live updates
  • FIBA M - EC17PSE replied to the thread FIBA Motorsport product updates 1G - 2G - EVO.
    · 126 27,070
    No different. They are M10 and four of them. They together are stronger than the 2 OEM M12 bolts so will not have any downfalls. The bar could be all in one but the machine time and costs would be a bunch more.
  • ItsTwan309 replied to the thread What did you do to your DSM today?.
    · 12,077 832,083
    Dude you bunny hopped, haha, that’s gotta be worth something
  • wing3r09 replied to the thread ECUflash 2G - EVO8 ECU - Won't Stay Running.
    · 3 324
    I do have a fuel pressure gauge, just not logged in EvoScan at the moment.Fuel pump setup is Areomotive eliminator that is wired to a controller and switched on manually. So during cranking and start up, fuel pressure is built and is holding at...
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 12,077 832,083
    Different build level lol. Here's a clip from the even life feed, I was only making about 10 psi on the launch here and it wasn't enough, the car fell out of boost for a split secYou must be registered to see element.
  • 91gsxproff replied to the thread FIBA Motorsport product updates 1G - 2G - EVO.
    · 126 27,070
    This is sick, I love the design just wondering how it will hold up with the bolt on pieces on the ends
  • Galant665 replied to the thread ECUflash 2G - EVO8 ECU - Won't Stay Running.
    · 3 324
    You sure the MPI relay is staying on once it fires up? Have seen this same scenario before. You got a fuel pressure gauge and it builds and holds pressure? Def want to select the map sensor you swapped to on the drop down menu in the map when...
  • Nickolision replied to the thread 98' Blueberry 🫐.
    · 29 3,514
    6/26/26Well the time has come for this engine to come out. But I did not expect it to be 15,000 miles later lolI first noticed a smoking issue through the exhaust, I didn’t really look into it until the smoking became more and more in...
  • Attempting to get car started after upsizing injectors from 950cc FIC to 1300cc Bosch High Impedance.Car is tuned via ECUflash and logged via EvoScan. Vehicle ran in the summer of 2025 on the tune and 950cc. Attempted to start this spring and...
    · 12,077 832,083
    Sheeesh. I stay low at like 5 haha all axels matter😂
    · 12,077 832,083
    That was about 15 psi, it's a little aggressive for my liking, I want about 15-20 psi but not that aggressive so I need to play with the 2-step timing table some more. Gonna make some more adjustments at the next track outing, it's loud as hell...
  • jesse12345 replied to the thread 2G Look for some helpful advice.
    · 9 605
    I agree but if he gets it for free it's hard to go wrong. I feel like I just went through this mess and I don't look at the value anymore. Everyone's different I suppose but I do see your side of things.
    · 12,077 832,083
    Sounds mean af!:cool: How much boost is it building?
    · 12,077 832,083
    Had the afternoon off so I did some work dialing in my 2-step. (headphone user warning!)You must be registered to see element.
  • steve replied to the thread 2002 Spyder Wiring diagram.
    · 1 198
    You must be registered to see element. might have what you're looking for. We don't have much if anything on the 3g Eclipse, we cover the 1G and 2G cars from 1989 to 1999.
  • 1990TSIAWDTALON replied to the thread 1G Needing a tune file stock 1g on SD.
    · 8 474
    Thanks @steve , that's what this forum is all about. Not DEAD END THREADS. So @slowspool91 , what was the solution to the problem so other readers don't have to look further? 🤔
  • codeshark replied to the thread 420A Need help car sputtering after engine swap.
    · 28 1,661
    the o2 sensor fixed it now it runs great other then when you go to start it you have to keep cranking it for it to start which may be the fuel pump ive change my fuel filter already
  • Rein3003 replied to the thread 1992 Galant VR-4.
    · 5 308
    I've also been collecting parts for the suspension and finally managed to get my hands on a set of original Advan RGs. They're 17x8.5 +37, which I think suits the Galant really well. I wanted something that looked period correct rather than a...
    · 5 308
    The plan for the engine is to keep it fairly simple. The car already came with an Evo III 16G turbo, Precision 1000cc injectors, a 2G MAF and an Apexi SAFC. Since then I've picked up a 1g with ECMLink V3 and an AEM wideband, which should give me...
    · 5 308
    Besides working on the car itself, I've probably spent just as much time hunting for parts.These cars are getting difficult to find parts for, especially here in Europe, so whenever something rare came up for sale I tried to grab it while I...
    · 5 308
    One of the biggest jobs I've tackled so far has been the complete rear suspension.Originally, I only planned on replacing a few worn parts, but as soon as everything was apart I knew there was no point in putting old components back on the car...
